My dishwasher will do nothing. The power is plugged in and the breaker in the garage is on, but it won`t come on. I have done nothing else at this point to check for additional problems.
Replacement parts for FRIGIDAIRE FDB126RBS2 Frigidaire/dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154441501.pdf
First thing to check is if the unit is getting power.
Just because the breaker is OK does not mean the unit is actually getting power.
Also have seen several where the connection at the wire nuts has gone bad.
Next would be the door switches.
These can be checked with the power off using a meter using ohms.
