Frigidaire washer leaking under
Please help, I asked the below question and got no answer so far. Thank you
I have a 9 yr old firgidaire washer and it leaks water under. I opened the lower front panel and neither hoses nor pump leak. There is a big cylinder or tube inside, made like from 2 parts, combined together in the middle with probably a gasket and visible screws every a few inches. The water comes from that combination where the screws are. Can anyone help please? what is the problem and how can i fix it? Thank you much
A model number will help a lot. But it sounds like you may have a bad tub seal.
Thank you much
I cannot find the model nr. I do not know where to look for it.
Can I replace the tub seal myself? or should I look for professional help?
Is it worth fixing?
Thank you again for your help
Paul
Paul:
You can probably do the repair yourself. However, a model number is necessary, in order to even come close to getting the right parts. Try looking for a tag near the rear of the machine, along the inner rim, just under the lid. If not there, try looking for a tag or sticker attached to the rear of the console.
