Frigidaire Refrigerator
Not cooling none of it Its a side by side and never side is cooling.Just happen all at once
Refrigerator not cooling not even the freezer happen all at once
Is the compressor motor running.
Check to see if the condenser fan at the back underneath near the compressor is running.
Are the condenser coils near there warm or room temp
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Yes the motor is running seem like the copresser is kicking in
Yes the fan is running and I also put another fan back there to help see if it will work.Cant get the air to goo over to the refrigerator side for some reason but it still dont tell me why the freezer not working.Just check everything seem to be working .
If the condenser coils near the compressor and fan underneath are not warm that mean the compressor is not running or if it is it is low on freon or not pumping freon. This requires a qualified tech to service.
If those coils are warm then the evaporator coils inside the freezer behind the back panel should be cool or cold and some cooling going on in the freezer. There is a fan above these coils which blows the cold air to the fridge side through a vent.
Yes There Is Some Freezing Down On The Bottom Part Of The Freezer.does This Mean Low On Freon Or What
The Coil In The Freezer Behind The Panel Is All Frooze Up And The Lines Too
You can defrost it with a hairdryer to get by till you fix it.
How to check stuff
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control
Your model number doesn’t match any I have access to to find if you have a timer or control. Model Number Locator
My ref. keeps freezing up and wont get cold.I have to keep taking hairdryer and unfreezing it so it will work I cant find the defost timer to check it My model is FRS23W3AWA and this is the model its right inside the door and says model number the serial number isLA34619140.I dont know what to do to find the switch for I dont know what it looks like.
I guess no one has an answer for me on this
