I try and wash dishes on any cycle option. All that happens is the tub fills up and then it stops. Afterwards if I hit cancel it will drain just fine. The machine is only 5 months old and we only used it about ten times. Any help would be greatly appreciated!!!
I forgot to add that it makes absolutley no noise after the tub is full. No whinning or clicks of any kind.![]()
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154768301b.pdf
It could be a loose wire since the unit is new.
More likely either the motor or the control board is shot.
Since the unit is new I would get it fixed under warranty.
If you mess with it then they could void your warranty.
