Frigidaire PLD4555RFC Dishwasher floods
We have a 3 month old dishwasher that has just started flooding. It seems to flood at about minute 26 or 27 of the 90 minute cycle. It seems that the drain is not pumping as if you open the door the water level is actually at the level of the door and there is more water on the floor. We do NOT have the DW connected to the disposal. OUr house has a seperate drain with a wye fitting above the main sink drain. We have run a snake down the drain and did not find anything clogging it. We also used a chemical to make sure it was clean. There is a cleanout in the basement below and there is no sign of clogging.
This problem just started and does not happen every time. When it seems to work properly, there is still a LOT of water left in the bottom of the dishwasher. I am used to seeing water in the bottom, but this is well above the level of the filter. Have cleaned the filter.
I knwo the simplest thing to do is to have a service tech come and do a repair as it is still under warranty, but want to make sure there is not something we are missing before we have to take a day off work to stay home and wait for them.
Any help would be MUCH appreciated.
Thanks in advance
Mitch
Hi Mitch,
Disconnect the drain hose and put it in a large bucket. Run the dishwasher and see how it will drain.
If the problem still exist then call Frigidaire for service.
If the dishwasher works fine then you need a plumber.
