Frigidaire, not filling fully, and not washing
Water comes in but not enough not raise float before it shuts off. Does not go into wash cycle.
Does float switch control fill valve, or is there also a time limit?
Does float switch need to be closed for circulation pump to engage?
Thanks for any help.
Wow, what an amazingly useless forum this is.
Found info I needed on You Tuibe.
Recommend others try that first.
