New Frigidaire Dishwasher model FDB1100RHQ0 - First used on Monday and worked fine all water drained out. While loading dirty dishes into washer on Wednesday I noticed the bottom was full of water and the hole on the inside left panel was slowly dripping water into the tub - any suggestions?.
I would replace the water inlet valve, it is leaking.
I am assuming it filled and ran OK when you did use it.
Sometimes valves will not close properly if the water pressure is lo but if it ran OK then pressure is probably OK.
Yes - it ran fine and dishes were clean. Will try replacing the water inlet valve. Thank you so much for your advice!
By the sound of it warranty should do the replacement.
Or you may be able to get them to supply the part at no charge.
