Found water leaking down the right side of the unit during what I think is the wash portion of the cycle- couldn’t figure out exactly where it’s coming from until I pulled the unit out and off the soft blanket/covering. Seems to be coming from around whatever vent(?) that’s at the top of the unit? Pics taken an hour or two after a cycle.
Odds are good that the gasket is shot AP2109646
There seems to be some confusion on the size.
The grid is one inch squares.
Click on the picture and a new page will open with a Q&A section.
Carefully check that the feed tube is not cracked.
Thank you. I went ahead and unscrewed the spray nozzle, flipped the gasket over and screwed it back together - it’s possible it was just loose? Gasket didn’t look that bad - but we’ll find out if that fixed anything on the next cycle. Thanks again.
And thanks for getting back to us, now when people search for the same problem they will see what actually fixed the problem instead of just suggestions on fixing it.
Follow up: seems to be good to go, no more leak. Whether it was the gasket needing to be re-seated or just tightened down - don’t know. All I know is I don’t think I could’ve brought myself to pay $23 for a friggin’ gasket!!!
