Frigidaire GRSS2352AF8 side by side fridge ice maker water line freezing
Brand: Frigidaire
Model Number: GRSS2352AF8
Main Symptom: No ice
What happens & when: Ice maker does not make ice sometimes. If I leave the fridge and freezer doors open for about 10 minutes it seems to start working again after about an hour. Guessing the water line freezes and if the compressor runs for a long time (after leaving the doors open for 10 minutes) it thaws out the frozen line and it starts working again. Freezer is set to highest setting of 4F. Thermocouple at ice maker water opening in top of freezer is reading a minimum of 7.5F
Parts or tests already tried: Repair man found a documented fix from Frigidaire to tape around the water dispensing hole. Repair man also said water pressure was not enough so I added a delivery pump and now it dispenses within spec (1oz per second)
Photos / video link: Frigidaire-Fridge-Ice-Maker - Google Drive
One possible thing that could be causing the fill line to freeze is if the water valve is leaking by allowing a small amount of water to seep into the line and freeze. You can check this by removing the ice make fill line at the valve and observing the valve for leakage
Thank you for the suggestion! How would I access the fill line?
Typically the water lines run up the back of the fridge and the valves are located at the bottom
RFTT2609 SXS Frozen Ice Maker Fill Tube.pdf (580.4 KB)
Frigidaire GRSS2352AF8 Refrigerator Service Data Sheet A18520603.pdf (516.3 KB)
Possible bad fill tube heater!
quite possibly they do tend to fail often
Thank you for the pdfs! Is the fill tube heater supposed to be on all the time? Or is there a sensor or something that tells it when to cycle?
If I understand the literature properly I believe it is constantly on
OK. I’m not sure what that heater is supposed to do because it looks like it just heats up the housing/cover and not the actual fill tube.
As a next step I’ll tape my thermocouple on that housing/cover and see what it reads before/during/after the fill tube runs water.
sounds like a good plan. The heater heats the tube by conduction and radiant heating of that area to keep the tube clear
I bought a new fill tube heater and installed it a couple days ago. The resistance of the new heater was 29 ohms vs 250 ohms for the old one. With the old heater the temperature around the fillter tube ranged from about 21F to 34F. With the new one the temperature is about 32F to 60F. So hopefully this new heater will solve my issue. I’ll report back after a few weeks.
thank you so much for the update
