Frigidaire gas dryer runs but no heat
I have a Frigidaire gas dryer, model # FAQG7001LW1, that is not working. As soon as I close the door the drum starts spinning even though I didn’t push the start button. There are no lights on the control panel when this happens. Even if I push the start button, before or after closing the door, the drum spins but no heat.
I’ve seen three different possibilities from replacing sensors to replacing the control board. I don’t mind replacing tue sensor but it’s 10 years old now. If it’s a control board them I’ll just buy a new dryer.
As the dryer motor is operating regardless of if the interface has been activated or not, there is certainly a failure in the control 137070890NH. This could also be the cause of the dryer not heating.
