Frigidaire FRS26EM8 no water
Brand: fridgidaire
Model Number:FRS26KF6EM8
Main Symptom:No water from water dispenser
What happens & when: no water comes out when switch activated. Changed water filter, problem persists. When I push in the water dispenser, I can hear something running.
Parts or tests already tried
Check to ensure the water is getting through the water inlet valve, then through the filter and filterhead assembly. Then check the reservoir to ensure it is not frozen up or cracked.
https://www.appliancepartspros.com/frigidaire-base-water-filter-240396002-ap3687338.html
https://www.appliancepartspros.com/frigidaire-tank-240545308-ap4032984.html
https://www.appliancepartspros.com/frigidaire-valve-242252702-ap5671757.html
Thank you for the reply!
I was wondering if you could send me a link to the water supply reservoir as well. I can’t seem to get to the pages where the schematics are, I will try today to get to them with a laptop, couldn’t find them on my phone. Thanks again!
