We have power to dishwasher, door switch is okay, but no lights, nothing happens. I think it’s in the control panel, but am not sure. Is there a fuse on the control panel? How can I check the control panel?
Thanks,
Norm
Thanks,
Norm
If you measure approximately 120vac at the control panel between connectors P1-1 (black wire) and P3-5 (white wire) and the unit still doesn’t operate, and you verified with a multimeter that the door switches are good, then the control panel ([COLOR=#800080]AP2109481[/COLOR]) needs to be replaced.
