My dishwasher was working fine and then this weekend I went to start a load and it will not advance on the dial. It just sits in the same spot. I can manually advance the dial and make it purge and fill at the start of the wash cycle but I cannot make it go through a wash cycle. It’s like that doesn’t exist anymore. We have had some bad storms recently, wondering if that has anything to do with it. Hoping to repair ourselves. Any ideas?
[quote=cmb78;245613]My dishwasher was working fine and then this weekend I went to start a load and it will not advance on the dial. It just sits in the same spot. I can manually advance the dial and make it purge and fill at the start of the wash cycle but I cannot make it go through a wash cycle. It’s like that doesn’t exist anymore. We have had some bad storms recently, wondering if that has anything to do with it. Hoping to repair ourselves. Any ideas?
Thanks![/quote]
Check the float and switch assembly(front left corner of tub assembly. Raise and lower float and listen for click noise. no click indicates a jammed float or bad water level switch, switch must close in order for timer to start motor in wash cycle.
You may have a damaged timer contact, due to the storms, but I would not make that the first thing to check.
You stated that you can drain(purge) the water indicating that the pump motor assembly is the least likeliest problem, at this point.
The float and switch assembly is the round piece in the front, left, bottom of the tub??? I did raise and lower it and it did make a clicking noise. Any other things I can test to rule in or out the timer contact?
Yes, the float is the round piece in the left front corner of the tub, and apparently working since you could hear the switch click.
Do you have a multi meter ?
At this point you will need to circuit check the float switch and fill valve solenoid circuits with a meter,and visually check the wires for damage, then consider the timer.
Make sure you shut off power to the dishwasher before you remove access panels, and start testing circuits.
[/size][align=center][size=3][/align]## [/size][size=3]Guangzhou, a provincial capital of Guangdong, is the largest and most prosperous city in southern China. It is situated in the mouth of the Pearl River Delta, with the Baiyun (White Cloud) Hill in the north and the Zhujiang (Pearl) River Delta Plain in front. The city is 125 kilometers northwest of Hong Kong on the Pearl River. The spoken language of Guangzhou - Cantonese - is incomprehensible to most northern Chinese, who typically speak Mandarin. A word in Cantonese has nine tones instead of the four tones in the Mandarin dialect. Learning to speak Cantonese is one of the benefits of Traveling to GuangzhouGuangzhou enjoys convenient accessibility. International flights from Baiyun Airport in Guangzhou Flights lead to many countries and regions including the Philippines. Thailand, Singapore, Australia, Indonesia, Malaysia, Vietnam and Hong Kong. Overseas tourists can reach Guangzhou by taking international flights or by arriving from Hong Kong. For Chinese tourists , they can take China Flights to arrive at Baiyun Airport ,Four cruises, three express hovercrafts, four express trains, eight flights and multiple express passengers buses travel between Hong Kong and Guangzhou. During holidays and festivals, a number of vehicles are added. The travel time is short and you can return within a day.Guangzhou are one of the top city of high level hotels in China Hotels. There are more than 1[font=宋体],[/font]400 star hotels in Guangzhou, ranging from the three to four-stars, the majority of them located in Guangzhou City. The prices of **Guangzhou Hotels**are relatively high, especially during the Canton Fair Seasons, due to the influx of business visitors pouring into Guangzhou. In the off seasons, the prices are much lower.
