Changed the Garbage Disposal and now dishwasher will not drain the water ?
Did you knock the Garbage Disposal plug out?
Below is the install sheet for this unit.
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154427301.pdf
Also the disposal install sheet should tell you how to do this.
