NO LIGHTS ON CONTROL BOARD.. Checked and reset breaker, checked wiring.Bypassed LATCH SWITCH..Nothing.. Do you think its the main board or the front panel insert..
Most likely the problem is a bad insert, but there is a small chance for the control board to be bad as well.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FDBB2865FC0 Frigidaire/dishwasher | AppliancePartsPros.com
Here is the Tech sheet.
Should I try the insert first? How does it come out and go in..It looks glued in.Rich
Rich,
I will definitely try the insert first. It is self adhesive but you have to disassemble the control panel.
