Frigidaire dishwasher doesn't dry the dishes
This dishwasher has never dried the dishes. They get clean but no drying. It has a rinsing and drying agent but the dishes are soaking wet. How can I change this. This is the first time I’ve owned a dishwasher that has left my dishes soaking wet. (this is my 4th dishwasher, always had Maytag, this is the 1st frigidaire) HELP.
Replacement parts for FRIGIDAIRE PLD2850RDC2 Frigidaire/dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154493101en.pdf
Here is the operators manual
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154575701.pdf
Are you sure you have the heat dry option on?
If yes then there are 3 parts in the heater circuit.
  1. The element itself. Unplug the unit and measure it, it should be around 15 ohms.
  2. The hi-limit thermostat. Unplug the unit and measure it. It should be 0 ohms.
  3. The control board itself.
If the first two items check out OK and the wires from the control board down to the element/thermosat combo are good then the board is probably toast.
