Frigidaire Dishwasher cycle selection issue
On the cycle selection, both the Normal and Both Racks buttons no longer work (the ones I most frequently used). All the other cycles can be selected. Help!:frowning:
[QUOTE=michellemcd@hughes.net;30062]On the cycle selection, both the Normal and Both Racks buttons no longer work (the ones I most frequently used). All the other cycles can be selected. Help!:([/QUOTE]
have same problem. answer?
[QUOTE=boogamax;71229]have same problem. answer?[/QUOTE]
What exactly is the problem? What is the complete model number of the dishwasher?
Gene,
I have the same issue and just installed a new board (154663005) and that didn’t correct the issue. It is a Frigidaire Model PLD2850RDC01. Some features still work and the new board has not had any impact. It is either the touch panel or the 2nd board the delivers the touch panel selections to the large board and ultimately the pump(s). Any ideas?
Thank you in advance,
Keith
Keith,
I would blame the membrane switch (insert) rather than the control board.
Here are the breakdown diagrams and Control panel replacement parts for FRIGIDAIRE PLD2850RDC0 Frigidaire/dishwasher | AppliancePartsPros.com
Did you find a solution? Im having the same problem. Thanks!
I’m having a similar problem too..but my selection doesn’t work to even stop they cycle. Anyone try to replace the membrane switche and have it work? I just don’t want to be ordering a handful of parts, instead of buying a new dishwasher. :slight_smile:
