Just recently, my Frigidaire dishwasher is not cleaning the dishes. Washing arms are moving, water temp is hot. Pulled out the trap around the lower arm and removed some gunk but still no luck. Are there more areas I should be looking at for clogs? Any help is appreciated. Also, what is the life expectancy of a dishwasher? Think this one is getting close to 10 yrs old.
[QUOTE=dlaudens;104264]Just recently, my Frigidaire dishwasher is not cleaning the dishes. Washing arms are moving, water temp is hot. Pulled out the trap around the lower arm and removed some gunk but still no luck. Are there more areas I should be looking at for clogs? Any help is appreciated. Also, what is the life expectancy of a dishwasher? Think this one is getting close to 10 yrs old.[/QUOTE]
The model number you posted does not come up. Verify and repost it.
[QUOTE=Hector58;104274]Same happening to me . I suspect is the [COLOR=#810081]Dispenser actuator [/COLOR]. I checked the solenoid and power is coming at different cycles but actuator does not move. (This the solenoid that open the detergent door)
The problem now is I can’t find the part. Have checked out by different methods and only showed for Whirlpool not Frigidare.
email me if you find the part
Hector[/QUOTE]
Hector,
Looks like your question is regarding a washer problem. It’s better if you’ll open a new thread in “Washer repair” section and post the complete model number of the washer and full description on the problem.
The model number you posted is incomplete. The link you posted is for the Whirlpool Duet Washer dispenser actuator assembly.
Gene:
Here is the model # from the label on the Tub.
FDB710LCB0
Serial # TH41722080
Thanks, Dave
Hi Dave,
Are they moving under the water pressure or when you turned them manually?
Can you hear the wash pump running when it comes to the wash cycle?
What is the water level inside the dishwasher?
Moving under water pressure and can hear the water pump running. Water is being sprayed to top rack. Water level is appx 1/8" if I measure near the heater bar/element and 3/4 to 1" in the center.
The water is lukewarm during the first part of the wash cycle. When it progresses and goes past ‘light wash’ then it is a little warmer. Heating element is cold during first phase but hot during second. Didn’t know if it should be hot for both.
