Frigidaire D/W electronic control panel
Dishwasher control panel was flasing ALL signals and starting on it’s own. Could not clear. We replaced the electronic control panel, it worked for about 2 weeks, then started doing the same thing. Comes on by itself, and has ALL signals flashing on LED panel. What else could be causing this problem?
You could try cleaning the ribbon cable connections on this part with a pencil eraser other wise it may been to be replaced or is that the part you already replaced?
FRIGIDAIRE Ss Console Asmy, part number: AP4297630
