Frigidaire Appears to have no power
When you close the dishwasher door and press START, the dishwasher appears to be dead. I test the voltage at the swith intrerlock and voltage is good. I tested the voltage on the control panel and I get good voltage there as well. I would expect to see one or more LEDs lit when I push START even if there were something wrong elsewhere in the dishwasher.
Is the control board bad?
Most likely the problem is with switch.Very small possibility it is control board. Start with replacing the switch. If that is not a problem then replace the control board. Remember - you can return parts that you don"t need.
The switch AP5736248
The board AP6285991
