Brand: Jenn-aire Model Number: Jenn-Air JFC2089HES Main Symptom: Freezer is too cold, have replaced the thermistor and the control panel touchpad, can’t get it into service test mode to see if the damper could be an issue or if the issue is related to the main control board. the refrigerator temp is fine. What happens & when:
Parts or tests already tried: thermistor and control board touch panel
Hey there! Since you’ve already replaced the thermistor and the control panel touchpad on your Jenn-Air JFC2089HES, I’d hold off on replacing the main control board until we do a little more troubleshooting.
One important thing to understand is that the damper primarily controls how much cold air enters the refrigerator compartment, not how cold the freezer gets.
Since your refrigerator temperature is normal but the freezer is getting too cold, I’m more interested in the freezer temperature sensing circuit, temperature settings, or the electronic control board.
Here’s what I’d check first
Verify the actual freezer temperature. Place a thermometer in the middle of the freezer and let it stabilize. Ideally, we’re looking for approximately 0°F. If it’s consistently running at -10°F to -20°F, that’s colder than necessary.
Check the temperature settings. Set both compartments to their recommended middle settings. Give the refrigerator about 24 hours to stabilize.
Check the refrigerator temperature. If it’s holding around 37–40°F while the freezer continues dropping well below 0°F, that tells us the cooling system is operating, but temperature regulation may not be working correctly.
Confirm which thermistor was replaced. This refrigerator uses temperature sensing to regulate cooling. We need to make sure the freezer sensor and its wiring are functioning correctly before condemning the main board.
How to enter service test mode
I found a Jenn-Air bottom-mount technical sheet for the JFC2089HEP model family that describes the following procedure. Your JFC2089HES may use the same control arrangement.
JustAnswer
Open the refrigerator door.
Press and hold the Door Alarm button.
While holding Door Alarm, press and hold the Refrigerator Temperature UP button for approximately 3 seconds.
Release the Door Alarm button.
Press Refrigerator Temperature UP once more.
The display should show 001 on the left and numbers or dashes on the right.
Use the Freezer UP and DOWN buttons to scroll through the service tests.
If this sequence works, we can check the temperature sensors and damper operation without immediately replacing another part.
If it doesn’t work, don’t assume the main board is defective. We first need to confirm that your control panel uses this particular diagnostic procedure.
What I’d like to know next
How cold is the freezer actually getting?
Which thermistor did you replace, and where was it located?
When you attempt the service test sequence above, does the display change at all, or does it simply remain in normal operation?
Those answers will help us narrow this down to a sensor or wiring problem, a control issue, or an airflow problem before you spend any more money on parts.
