Freezer door light STAYS ON after door is closed
Brand:Samsung
Model Number:RF28R7351SR
Main Symptom: when freezer door closes, the light stays on
What happens & when: when freezer door closes, the light stays on and sales person can’t seem to find a part to change
Error Code (if any):no error codes
This could be caused by a missing magnet, a damaged pressure switch that houses the magnet, or even a damaged reed switch. If you grab a refrigerator magnet and open the freezer door, there should be a rectangle just below the left rail near the front. If you place the refrigerator magnet here, does the freezer light turn off?
There’s a rectangle on the main cabinet door on the left below the rail to the freezer drawer. I thought that was the problem, but couldn’t get a part number from parts department (which is usually incredibly helpful.) I put a magnet on that and the light didn’t turn off and the magnet didn’t hold. Here’s a picture I got without taking the drawer out, by squeezing my hand in behind the freezer drawer.
On the freezer drawer under the rail is a plastic thing that definitely held the magnet. Light did not go off. It that it? Second image.
Is that it?
thanks you for your prompt reply, Barb
The first image is the reed switch that should turn the lights off when activated by a magnet. More than likely, the reed switch has failed. DA34-00043J Refrigerator Door Reed Switch | Genuine Samsung OEM In Stock
Awesome, thank you very much. I will order one immediately.
You all are fantastic!
barb
Well, I received the correct part from APP, installed it (very easy) and the light did NOT GO OUT. I did clean out the freezer though.
PLease help me continue to trouble shoot this.
Barb
Is it true that this same switch controls a fan? Is the fan now running non stop? What if I just pull out the light?
Also, with this frig, the ice maker place is leaking and ice is forming on the outside of the ice maker. I took pictures and hopefully will get some response from Samsung (I heard they lost a class action suit about it), but I can’t seem to stop it from staying frozen, even though I turned the ice maker off.
Thanks, barb
I just noticed something. When you open the flex door (that middle drawer between the freezer and refrigerator) after about 6 inches, the freezer light goes out. Is that significant? And of course when the drawer is closed, the light stays on.
To clarify, the light that won’t turn off is mounted under the door to the flex zone drawer, and shines into the freezer when freezer is open.
make sense?
thanks, barb
Help please. I wrote yesterday and haven’t heard. I ordered and replaced the reed switch but the light is still constantly on. I’m afraid that I will burn up the fan that someone said is also connected to this.
Please let me know what to do next, or what part to get next. I can’t find the magnet or the pressure switch in parts dept.
The fan should not be a concern as it is operated solely when the main control senses the air being to warm. The flex door being opened and stopping the light from illuminating is information worth investigating. If you open the flex drawer and inspect the wire harness on the right rail, does it look like there might be any sections of wire that have been damaged or severely pinched? I ask because the freezer LED wires would be in the same section.
Actually, the flex door light stays on whether the door is open or closed. Because it is ALWAYS on, I can’t tell when I open the freezer door is that has anything to do with it.
changed out the wire harness in flex door, and changed out the control board. worked for two days then light came right back on. will try a new control board, but if that doesn’t work, I’m completely stumped. thanks for your response.
I just thought that maybe the replacement reed switch in the freezer was bad, but the wires looked good. It was extremely easy to replace, and the cabinet was totally clean, so why would anything just happen to that switch?
thanks.
It would be very unlikely that the new reed switch is faulty. Just to verify, placing a refrigerator magnet onto the reed switch for the freezer does not get the light to turn off?
