Fixing Plastic Covr-Choke - best glue/sealant to use
Brand: Kitchenaid
Model Number: KHM155SS
Main Symptom: Recommendation for glue
What happens & when: The plastic Covr-Choke is cracked
Does anyone know what the best glue/sealant to use to fix a slightly cracked Covr-Choke ?
As long as there is not a big gap between the crack, it will not effect the the operation of the MW. That being said, any type of glue that you would use to repair plastic should work.
Thanks David - what about a silicone sealant like Silco 4500 ?
Any particular glue you can recommend ?
Any kind of non-metal based glue will work.
