Fisher Paykel Dishdrawer - Wood Peeling
My Fisher and Paykel Single Dishdrawer is causing the cabinet underneath the drawer to become damp and the paint is beginning to peel. Any ideas what the cause of this is?
Hello,
Sounds like you may have a install issue, if you don’t still have the install manual one can be found at the bottom of the links home page.
If you could post pictures of the unit installed I could help you a little better.
If you want to check the fan on the front of the dishwasher the front panel will need to come off. Here is a video that explains how to remove the front panel on a DD603 & DD605
DD603 & DD605 Repair Video
