Fills with water then drains plz help
The dishwasher will fill with water and start to run for about 30 seconds then the drain pump will kick in and drain the water from the tub. then the motor will hmm the rest of the cycle with no water in the tub. Any suggestions would be greatly appreciated been trying to find a solution to the problem all day on the net with no luck. I have all tools to do any diagnostics someone may suggest.
added info maybe it helps the digital display shows 2H the entire time it is running .
Any suggestions would greatly help.
