Fills+drains pump runs but wash arms not moving
Hi All,
Dishwasher fills can hear pump turn on after fill but wash arms are not moving. It will drain itself with out problem.
Open the door after the pump engaged and check the water level and if the spray arm is spinning.
Post your findings.
No not moving the dish’s are dry and the motor is running. Hmmmm…
Thanks again
Most likely the problem is a bad pump which has to be replaced.
Here are the break down diagrams for the White Westinghouse dishwasher Model MDB124BHS0
