fan in freeze doesn't work
please help. Freezer has cold air but fresh food side is warm. I cleaned all dust and blockage from back and front of fridge. Water line inside was frozen, thawed it and water dispenser works again but no ice. I locked in back panel of freezer section and saw that the fan is not working. Fan in back of fridge works fine. How do I fix this?
thank you
Pull the evaporator motor,strip the wires and plug it in the wall socket, if it fails to run, order one here (5303918549)
