Explaniation of how drai operates
the drain is only working intermittently, the same motor drives the wash cycle as the drain and is running fine. Wanting to know how the pump switches from pumping (Since they are located in the same housing) the water through the wash cycle to the drain valve so i can troubleshoot it. Here is the link to the exact machine cut away.
Pump and motor replacement parts for WHIRLPOOL TUD5700EQ2 | AppliancePartsPros.com
This should help. The first section looks like it applies to your unit.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/56e33eb0e839a7fa85256a8e00510938/$FILE/4322430.pdf
