I have a Kenmore washer that fills and drains. That is about the extent of what it is good for. Upon completion of filling, it makes a whirring sound like it thinks it is agitating, but it doesn’t. It also like to make a similiar “ratchety” noise when it thinks it is spinning, when it really isn’t. Any ideas as to what my problem could be? I had thought that maybe there was a broken belt, but it is either a direct-drive, or very well hidden.
The problem is a broken motor coupling. No doubt about it.
- The part number for the motor coupling is AP3963893
The instructions are attached to the reply.
How to remove the washer cabinet.pdf (43.5 KB)
How to remove the pump.pdf (42.3 KB)
How to replace the motor drive coupling.pdf (39.5 KB)
