washer will not start, flashing eror code normal wash/cancel drain.
I checked water and drain and turned off and reset breaker.
Any sugestions?
Remove the access panel at the bottom of the washer and look for the tech sheet. Run it through diagnostics to test the different parts of the dishwasher.
