Error Code FE
I am getting an error code FE on my dryer which stands for Improper / irregular power source. Nothing has changed in my setup it is still plugged into the same outlet the last 4 years, and the washer is connected to the same outlet and works fine. Any ides what may be wrong or have to be replaced?
Bad receptacle?
[QUOTE=SublimeMasterJW;142820]Bad receptacle?[/QUOTE]
Sublime, thanks for the response. So you think maybe the receptacle is bad or the polarity is reversed even though it has been hooked up for 4 years? The washer is also hooked up to the same outlet and I even tried switching them and the dryer still doesn’t work but the washer does. I will check to see if that is it, thanks.
I would replace the wall receptacle before buying any dryer parts
