ER code
I’ve had to replace the main board abount 10 months into owning this unit because it just died and would not run. now the display keeps flashing ER is the same board dead? the unit is now out of warranty, please advise on what board or part needs to be changed.
Replacement parts for PLD4375RFC models | AppliancePartsPros.com
Here is a manual
http://frigidaireservicetips.com/pdfs/463_9.pdf
Try to run the service test.
Could be the board is shot again.
I am not sure about the specifics of how this configuration error works but perhaps one of the other devices is open and it comes up because it cannot see it.
Try turning the breaker off for 5 minutes or so to see if it will reset
Try the connector cleaning
Measure the other components with a meter
If all the above are OK then odds are the board is gone again.
Connector Cleaning
Unplug the unit
Open it up
Clean the edge connector.
