I didn’t know if you could help me figure out why my dishwasher stopped working all the sudden. It went through a normal, complete cycle then the next time I went to use it, it would not work at all. There is power to the unit but not to the Hi-limit thermostat. Would that part make the whole dishwasher not work? Any other ideas?
Replacement parts for KENMORE 66513832K601 | AppliancePartsPros.com
If you mean the hi-limit that is connected to the heater then the answer is no.
More likely it is the thermal fuse on/at the control board in the door.
AP4423189
If it is blown be sure to use the new wiring harness that comes with the fuse.
Also you can click on the picture for more views and a Q&A section on this part.
Click on the Q to see the A.
