Electrolux Washing Machine Model # EWFLW65HTS0 Door needs to be pried open at end of cycle or when it is closed
Brand:Electrolux
Model Number:EWFLW65HTS0
Main Symptom:Door
What happens & when:Won’t open after cycle
Hi this is the part your then likely that your going to need to help you from having to pry your door open. its the door lock mechanism Frigidaire 134629900 Washer Door Lock Assembly | Genuine OEM Part
