Electrolux Model#ELTE7300AW0 Serial#4B43413208 Dryer makes noise when running
Brand: Electrolux
Model Number: Model ELTE7300AW0
Main Symptom: Dryer makes noise when running
What happens & when: This is a stacked laundry unit, with the washing machine located below and the dryer above. The dryer began experiencing an issue three days ago; initially, the noise was faint and occurred only intermittently, but now it has become very loud and persists throughout every cycle. The sound resembles the rushing of wind, or perhaps the friction of metal parts rubbing against one another. I observed that the dryer operates normally for the first minute or two after starting; then, a faint noise begins, gradually increasing in volume until the loud noise becomes constant. I have cleaned every accessible area—thoroughly removing all accumulated lint—yet the noise persists. The only time the noise ceases is when I attempt to physically move the machine. On one occasion, after I gave it a push, the noise vanished; however, within a minute or two, it returned.
Photos / video link: Dryer - Google Drive
I haven’t disassembled the dryer yet. I would like to know which parts I should purchase, as—since it is a stacked unit—taking the dryer apart will be quite a hassle. I want to replace and lubricate all the parts that might potentially need attention in a single operation.
Look at this service tip.
LNTT2631.pdf (1.8 MB)
ELTE7300AW0.pdf (5.4 MB)
LNTT2516.pdf (750.4 KB)
