Electric Oven Issue - Worth Repair?
Gene,
I received the bake element today. I installed it and the oven does not heat up. When I set the control panel to bake it just display initial 100 degree reading and does not increase. It does make the click sounds if you increase the preheat temp setting, but never heats up :frowning:
The Bake element out of the box reads 16ohm, I thougt it was supposed to be about 18.6:confused:
I, of course have no idea what to do now. The cooktop still works. Here are a couple pics of the new element and the connection on the rear of the unit.
Back connections…
