Electric Dryer
I have a Frigidaire Dryer, Model GLER642AS0. The motor does not start, but if I turn the drum by hand, the motor will work and the drum tumbles, and everything else works just fine with the dryer. I need to find out what part I need to get the motor to start, and order it.
Sounds like the start windings inside your motor … In order to correct this problem the motor will need to be replaced. AP2107144
