Ed kahle
The dishwasher fills and runs cycles but wont drain out. It sounds like the solinoid engages but the pump does not pump out the unit. Does this sound like a bad or seized pump?
If you can do a voltage test, look for 120VAC at the pump, while it’s supposed to be draining. If not, you may need to replace it.
AP4019644
