Brand: Bosch
Model Number: SHP65T55UC/07
Main Symptom: E20, Power Loss
Error Code (if any): E20
Parts or tests already tried: Control Module swap
Brand: Bosch
Started out with e20 error code. Troubleshoot the drain and circulation pump. Circulation pump read 15.5 ohms each, drain pump read 128 ohms each. Them being consistent seems like they were fine or within spec. Everything hooked back up, now the top panel is showing visual power. Thinking maybe the control module somehow got messed up i replaced it. Still the same problem, no visual power.
My wiring schematic got ruined from water damage so i don’t know what wires to trace of voltage or power. The on off button is receiving power and sending it back to the control module. but nothing displays on the top “screen”. Please help.
