For a while the DW wouldn’t start. I reset by powering off and it worked a while. Now lights go on but will not start, no water goes in. When hitting start again I can hear the drain pump trying to get water out. Hard reset does nothing. Element gets hot, timer runs etc. Could this be amotor issue, inlet valve, float How to check? Thanks
