Dw motor won,t start
i just replace the motor & pump i turn it on the water fill up
then wait for the motor to on then heard a click waited to see it start
nothing then i push cancel/ drain then motor started ran for 10 second
then stop
i replace because the other one was leaking & the motor burnt out it started to smoke
You may have jammed something in the pump, just take apart and check. If ok, you may need to check your winding current per the schematic, could be a start relay/timer problem.
