The buttons on Dish Washer are VERY hard to press to start the mach. For a while if I held then down, pressing very hard the the mach come on. It recently had “PF” blinking light, which I was able to reset but now even it I press and hold the buttons nothing happens… It does not start…nothing lights up. What part do need?
Sounds like you may be dealing with two problems… #1 the control buttons are bad and probably need to be replaced. #2 (PF) means power failure…so ether your home lost power or possibly the electrical connection to the dishwasher is having problems. many dishwashers are direct wired (not on a plug) the wire nuts may have come loose. Make sure you turn the breaker off before you start poking around with a screwdriver. Breaker Panel Basics
[quote=GPG1;417558]The buttons on Dish Washer are VERY hard to press to start the mach. For a while if I held then down, pressing very hard the the mach come on. It recently had “PF” blinking light, which I was able to reset but now even it I press and hold the buttons nothing happens… It does not start…nothing lights up. What part do need?
Glenn[/quote]
Glenn,
Appliance Assistant, was most likely correct as far as the “PF” display, it seems you solved that particular problem.
As for the buttons, you have a printed circuit board with “mini” buttons mounted under the touchpad assembly, you may need that part
But before you replace the touchpad board, try this.
Dismantle the door(see below) disconnect the touchpad ribbon from the control board, clean the insertion end of the ribbon, and the connector on the control board with rubbing alcohol, and clean as best possible, allow a few minutes for the alcohol to evaporate then insert the ribbon and test for programming. If that fails order the touchpad printed circuit board.
Thanks and
Good Luck,
[FONT=Helvetica][SIZE=3][FONT=Helvetica][SIZE=3][LEFT]1. Disconnect dishwasher from power supply.
2. Remove outer door panel (see Service and Disassembly section labeled
Door Panel).
3. Lay outer door panel face down on a protective surface.
4. Compress plastic retainers with a pair of pliers to release the electronic
control from carrier panel.
5. Lift control from mount.
6. With the control removed, pull protective shield back to free ribbon from
keypad assembly.
7. Remove two screws holding outer door reinforcement to outer door panel.
8. These screws also hold the door handle in place.
9. Do not drop door handle.
10. Remove this reinforcement to gain access to keypad assembly.[/LEFT]
11. To install parts, reverse procedure.
[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=6][FONT=Arial][SIZE=6][LEFT]DOOR PANEL[/LEFT] [/SIZE][/FONT][/SIZE][/FONT][FONT=Helvetica][SIZE=3][FONT=Helvetica][SIZE=3][LEFT]In order to access the electronic controls, the outer door panel must be removed from the door assembly.
Disconnect power from dishwasher.
The outer door panel is mounted to the inner door
panel by Phillips head screws .
Removing the outer door panel will expose sharp edges on the inner door panel.
Be sure to support outer door as screws are removed to prevent damage to outer panel and dishwasher.
Remove wiring harness from control and ground connection on door panel.[/LEFT]
The outer door panel is disconnected.
CHAMBERSBURG, pa - a 10-year-old girl in central Pennsylvania allegedly caused a severe shake the infant death, throwing him into cribs, was accused of murder. Level 3 Fifth grader charges for - on Friday in franklin county coroner appeared dead after the trial of 11 heath ryder. The girl was released into the custody of the blood and ordered without their parents unsupervised contact with children under the age of five.This is not a child, have a mental health disorders. She didn’t have a personality disorder," the girl’s lawyer, Jason Kutulakis Chambersburg, tell public opinion. "She is not a bad man. She had no history of behavior problems or school problems.“Dottie charges Friday is Bowers, 56, two children babysitter, who is in her hometown, pa., near Shippensburg earthquake hit occurs, on July 29.Involuntary manslaughter was charged with endangering the welfare of a Bowers, children for suspected failure, while not to seek medical care for the infant. Rider traumatic brain injury and death toll at a hospital in August 2.Our goal is to cooperate with police and find out exactly what happened,” said Joseph Caraciolo Bowers “lawyers strategy simulation exercise”. "When Dottie have her chance, she will tell her story."A judge immediately transferred girl’s case, in juvenile court records are sealed. Pennsylvania law requires murder charges, thus avoiding the to the defendant in the age of the adult court regardless of district attorney Matthew Fogal display, supported me, transfer the case to the juvenile court. The suspect was 9 when the baby was injured.================Google提供的广告================= 问道赌钱网上赌钱网站网上怎么赌钱网上赌钱游戏澳门赌钱 ============================================
How does one reset the machine when the PF light is blinking? I can’t seem to find this anywhere. Thanks in advance.
Glenn[/quote]
Edit: ok, I found that opening and shutting the door should do it. Well, that wasn’t doing it. I’ve been having control panel problems with this machine for the last 2 or 3 years, and it is 5 years old. I slammed the door shut several times and the sensor finally picked it up. Able to wash again. When programming the wash, you can’t track what you are doing on the machine. You have to closely pay attention to what you are doing. My wife was pushing a bunch of buttons on it last night as she was having trouble getting the machine to do what she wanted it to do. I don’t know, but it is liked she temporarily jacked up the programming on it, so I hit the breaker on it to reset it. This led to the PF message, and I suppose I couldn’t ditch it because of this control panel and sensor problem. Just by way of further example, the machine can’t tell when the door is open or closed. You can run the dishwasher with the door open, for example. The cycle does not stop when the door is open and hasn’t for years. You get no readout on the digital display pad except on rare occasion and depending on the position of the door (open, closed, barely touching, etc.).
[quote=twosomeca;467744]How does one reset the machine when the PF light is blinking? I can’t seem to find this anywhere. Thanks in advance.
Thanks again. Comments welcome.[/quote]
Glenn,
Now, it sounds like you’ve got a problem at the door switches and or wiring.
When you dismantle the control panel, and door , you’ll be able to investigate the switches and wires as well.
