DV42H5200GP/A3 Samsung Gas Dryer does not heat consistently
Hi All,
I have a samsung gas dryer that heats minimally. I have torn it down and tested the following parts
Sensors:
Thermistor at 48F garage temperature reads 17 - 18k resistance. not sure if this value is acceptable.
Dryer Thermostat continuity is good
Dryer Radiant senor assembly continuity is good
High limit thermostat continutiy is good
Components:
Igniter gets bright hot
Coils at 48F reading ok 3 prong readings ~1500 ( outside and middle) and ~600 ( outside to Outside)
Observation: when the dryer turns on the drums spins freely. 10 seconds later I hear the first click at which point the igniter starts to heat up. 5-7 seconds later gas valve opens and there is ignition. At this point the ignition stays for 5-7 seconds and gas gets shut off. I read on this forum that the coil may function when they are cold but once they warm they could malfunction.
looking for some guidance on what to do next?
You’ve got either a weak hi-limit thermostat AP4201898, a weak flame sensor AP4201717, or a bad valve AP4203162.
Get to where you have access the hi-limit thermostat on the heater assembly, run the unit and wait for it to quit heating. Once it stop, unplug the dryer, disconnect the wires from the thermostat, and take a continuity reading across the terminals on the thermostat. If it is open then the thermostat is weak.
If the hi-limit is good then you’re down to the flame sensor or valve. The flame sensor usually opens about 7-15 seconds after ignition, so I’d probably replace that before the valve if it is opening 5-7 seconds after ignition.
https://www.appliancepartspros.com/samsung-therm-dc47-00018a-ap4201898.html
https://www.appliancepartspros.com/samsung-radiant-sensor-dc32-00008a-ap4201717.html
https://www.appliancepartspros.com/samsung-valve-dc62-00201a-ap4203162.html
Thank you! I tested the hi-limit and it tested ok. I will start with replacing the flame sensor and report back.
