Duet starts to beep after 20 minutes running
I have a electric dryer that has started to start to beep while running. It continues to run and we just open the door, shut the door and hit start and no further problems.
Electric dryer that the lint trey is cleaned after every use. Hose is hooked up right? Littel help?:confused:
Your machine should still be under warranty so you should contact Whirlpool for service. Look at your warranty and you may have a 2 year warranty on the CCU (part only) if you have had the dryer for more than one year.
You could try and unplug or shut the power off to the
unit for at least 1 hour. Its worth a shot.
