Brand: jenn air
Model Number: JEC0530ADB
Main Symptom: dual element doesn’t heat up
What happens & when: When I touch the control for the dual element (front right) nothing happens. if I trip the breaker (for 1 minute) then turn it back on, all the lights come on for about 10 second (resetting?) then I am able to select a temp for the dual element but it doesn’t get hot.
Error Code (if any): none
I took it apart and found the element was rusty in the limiter switch. everything else looked good so I bought a new element (W10823717). The pictures on your page shows an Epic sensor with long wires (other, cheaper company’s had a short wires) so I bought it from APP. When I received the element it had a short cord and the instructions said to use the old Epic sensor. Thinking it was the rusty limiter switch, I installed it. It does the exact same thing! Through my research I found out that the epic sensor can cause the element to not receive power, but with the old one installed I don’t know if that is the problem. Also, When I checked for continuity, it didn’t have any and neither did the new one.
Any help would be appreciated.
