Dryerlights flicker at start and resatart
Brand: maytag
Model Number: med7230hw2
Main Symptom: light flicker
What happens & when: at start and restart
Error Code (if any): power failure hit to continue
Parts or tests already tried: replaced power cord, terminal block, terminal wires
Hi, if your dryer is showing a PF (Power Failure) code and the control panel is flickering, it sounds like the dryer may be losing power when it tries to start. There are a few things I would check before replacing any parts.
  1. Check the circuit breaker: Go to your electrical panel and locate the dryer’s double-pole breaker. Turn it completely OFF, then firmly back ON. Sometimes a breaker can partially trip or develop a problem that causes power interruptions.
  2. Check the outlet voltage: If the breaker is good, the next step is checking the outlet. An electric dryer should have approximately 240V between the two hot terminals and 120V from each hot terminal to neutral. A loose outlet connection can cause voltage to drop when the dryer starts. Because this involves live 240V electricity, I recommend having an electrician perform this test, especially under load.
  3. Reset the control board: Unplug the dryer or turn off the breaker for 5–10 minutes, then restore power. This will help clear a temporary control board glitch.
If the breaker and power supply check out but the panel continues flickering and showing PF, we may be dealing with a failing main control board or a loose wiring connection.
I would start with the breaker reset first, since that’s the easiest thing to check.
Thanks for the response. I appreciate it.
The ceiling lights in the laundry room flickers. Dryer works. I waiting to see if the note shows up.
Thanks and have wonderful day.
