Dryer
our dryer just quit. you can turn it on and the control lights all light up. when you press start, it clicks and nothing happens. the clicking noise is in the top panel. Any ideas?
Replacement parts for WHIRLPOOL WED6400SW1 29`` ELECTRIC DRYER | AppliancePartsPros.com
Here is a manual
Whirlpool 8178584 Cabrio Dryer Service Manual - ApplianceDigest.com
You will have to join the site to get the manual.
I am assuming that the interior light works and everything else looks normal.
If yes then I would check:
  1. Belt switch - could be just a broken belt.
  2. The thermal fuse - if it is blown clean/check your vent system as this is the most common cause of it blowing.
Note: The parts breakdown does not show a thermal fuse while the manual does (Page 5-2). I do not know which is correct.
