Maytag neptune electric dryer MDE7500AYW shows power failure occured when I try to start it. I reset it and and keeps doing it. What should I check or do?
Replacement parts for MAYTAG MDE7500AYW | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag_library/docs/16023110.pdf
Cannot be of much help here hopefully someone else with more knowledge will jump in.
I am not sure how they monitor the power so the best I can do is suggest you check all the electrical connections (plug, receptacle etc.) and the connections in the unit.
You could try getting into the diagnostics to see if anything pops up.
The following may be worth a try:
Unplug the unit
Open it up
Clean the edge connector.
I just checked the thermal fuses. and they are fine. I checked the door switch as well. I think the dryer stopped functioning after the thunderstorm. Is there a PCB or control board that could be fried?
is there a place i can locate the service manual for this…
Thanks…so much..
Gene, thanks for the infor. My problem seems to come and go. If I keep trying to start the dryer it clicks and screen shows power failure occured. It sounds like a relay is trying to kick in but then kicks out. I continue to reset it and try again. After reseting it 3-4 times it works. Serveral weeks goand it acts up again with the same problem. So far I keeping reseting and it seems to keep working. I figure it’s only a matter of time before it fails completelyl
[QUOTE=denman;101786]Here are your parts
Unplug the unit
Open it up
Reconnect everything and give it a try.[/QUOTE]
Hey, denman: Your response here reminded me that quite a few years ago (less than ten), I saw a fixture that techs can use to do continuity tests on ribbon connectors. Do you remember such a tool? I’ve tried unsuccessfully to locate it.
magician 59
Sorry have never heard of it.
Perhaps try a post in the tech forum.
You said the definitive word: Thunderstorm. I would recommend you do a visual check on the circuit board in the console. [COLOR=“Red”]Unplug it first[/COLOR]. See if there is any obvious burning of any component on the board. Inside the console you should also find the tech sheet (unless a previous tech stole it–that’s one of my pet peeves). It should offer some basic troubleshooting and info about diagnostic mode.
