For the last couple weeks my dryer just hummed when you pushed the starter and then it would start. Now it just quit working. I bought a used dryer off of craigs list last night and it’s doing the exact same thing. Please tell me this isn’t just bad luck. Can there be a problem with my 220 outlet because this new dryer looks like new and I can’t imagine that both dryers have the same problem.
Yes it could be low power you will have to check it.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
Usually the L1 (black) to Neutral (white) is power for the motor
If OK
If OK
Be careful as 240 volts is lethal !!!
If the power measures OK. Then measure the L1 side when someone else starts the unit to see if the voltage drops. Best to have a second person start it as you want to concentrate on the meter leads so you do not get a shock or an arc/spark.
