Dryer wont start at all!
My dryer wont start at all, I figured it was the fuse and replaced it but it did not work. I tested the theromstats and think they are good but am not sure. plus i dont know where to latch the spring back down for the tensioner on the belt. it was off when i pulled the back panel off. please help! I have 5 kids and the clothes are piling up fast!!!
Replacement parts for General Electric DVL223EA0WW Electric dryer | AppliancePartsPros.com
The tensioner spring being off may be your only problem.
The unit has a belt switch (Item 1349 in Section 4) which will kill power.
Here are couple links that should help you put it back on.
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
http://www.applianceaid.com/images/belt-config.JPG
Thanks for taking the time to respond. Turns out the fuse i purchased and installed first was bad. Who would have thought to check the brand new fuse?! the dryer is up and working and the mountain of dirty clothes is dwindling.
